That adapter you have for the xt60 to deans, isn't ideal. It'll work ok for a while, maybe even aslong as a battery connector would last, but its another possible failure point. I would recommend eventually to solder on a new connector on your esc. Get the Amass brand xt60s, they are the proper brand, and not some cheap chinese knock off. Suppose you could have the LHS do it once they go back to doing repairs, but honestly soldering is one of those things you should eventually learn. It'll come in quite handy in the rc world.
Another good thing to have is one of those hand held IR thermometer. Good idea to monitor motor temps. Don't want the motor to go much over 160 degrees farenheit. Even the cheapo ones seem to be pretty accurate. I have a cheap one, and a nice expensive fluke one I use for work, and they both read pretty close to the same temp, close enough for rc electronics.
Keep an eye on the wheel nuts (mainly the rear), check them every other run or so. They tend to back themselves off a little, and then strip out the hexes.
Get yourself a new bearing kit (rubber seals, not the metal sheilds), and check all your bearings when you do the metal transmission gears. Its a good idea to have extra wheel bearings on hand, so you can change them the day you need to, not days later after ordering them after you discover you need them. I take the rubber seal off with a razor blade and pack in marine grease, and put the seal back on. It does add more resistance, but they last longer. Wouldn't do that if you are racing, but general bashing is fine.
Just a few pointers, I could keep rambling on, but it's start.
