Rear axle compatibility???
Kingsauce
Does anyone know if there are different rear axles I can run or better yet a entire driveshaft upgrade. Just snapped the stock one, and the local part store is out. Any help appreciated :)
Btw I got the ECX Amp MT thxs
Hi there I have the same truck and there are a few upgrades for the axles. On eBay you can find metal axles for the 2wd circuit and boost and they should fit most 2wd ecx models. I hope this helps
Slash steel driveshafts
I use these, they have lasted a while for me, no issues yet, on 3s 3200kv with low ish gearing. They bolt right up, but need different wheel hexes and also a spacer behind the hex on the bearing side of the hex to reduce play, but that's cause I'm using somewhat narrow wheel hexes from a redcat gen8 i had lying around.
Could I get some better pics of the spacer you’re talking about?? I have a 6500kv spektrum on 3s and I’m getting bigger tires so I already know the rear driveshafts are bound to blow
Hello sorry for such a late response heres all the images: i gave the measurements also. These calipers arent the mosr accurate, maybe I'm just bad at using them but as long as its close, it should be fine. I kinda did some changes recently like different links and stuff so that might look different. Also you probably want narrower rear hexes as mine are too wide and i have a narrower wheel nut on there to compensate.
Much appreciated, I’m ordering the same ones and I’m sure my hobby shop in town has the spacers that’ll work.
Hi I like to use traxxas #6852A vxl heavy duty rear drive shafts. with a little bit of drilling the Differential connection out they work perfect. Used them with 3s castle and specktrum brushless combos. Ive used them on my circuit, torment, and ruckus all 2wd
