ECX Torment/Ruckus 4WD Driveshaft Replacement
305HemiGuy
Hey guys, I was wondering if someone could direct me to a tutorial or youtube video showing how to replace the long driveshaft in my 4wd torment (the one going from the rear to the front transmission. Because these vehicles are increasingly rare, it's becoming harder to find simple tutorials. The little metal pin that couples the driveshaft into the transmission fell out during a run. Luckily Amazon has a couple driveshafts left in stock.
@slick2500 Is correct, it's a 1/10 scale Torment.
No videos that I could find, there isn’t nearly as many 1/10 4wd as there are 2wd. But here is my build thread. A ruckus is a little difference but close and 95% of parts are all 1/10 4wd interchangeable.
https://www.ecxforum.com/threads/1-10-4wd-build.3326/
You’re essentially just trying to get the ECX231011 upper deck off. Lots of Phillips screws. Getting the battery out gives you a little visibility and gets some wiring out of the way. There is a plate over top the spur gear/slipper and a small cover over the pinion that will need to come off first. Lots of Phillips screws many different lengths and threads so you may want to take pics as you go or use the cardboard organizer trick.
Once that top deck is off the whole center driveshaft will be exposed. Rotate the slipper until you see where it connects to the rear diff come to 12 o’clock and the slipper and center shaft will lift right out.
ECX232015 is the center shaft for a Ruckus and nobody has one (Ive been looking). Is the one for yours different or can you share your source I need one? If it’s just the pins, I believe I may have the rebuild kit you need new in bag if you want me to look. I damaged my actual shaft.
@95PGTTech Thanks a ton! Your posts were extremely helpful. I'm not sure if we can post links here, but here is the Amazon link to drive shaft I ordered https://www.amazon.com/gp/product/B00ITV8KDG/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1 It says they only have 1 left in stock so hurry up & grab it if it is indeed the part you're looking for. It says it fits all 4wd Ruckus & Torments.
I'm not sure either, but yes, that's the right part number. You're awesome dude, thanks! I was looking at one I was going to have to get from Australia. Super cheap, but expensive as hell to ship and over a month wait.
I know this is an old thread but does anyone know where I can get this drive shaft? And as a side note have you replaced the spur gear with a metal one?
Amazon doesn't have it in stock at the moment, but it could return again. I've seen it happen before with that drive shaft. Or you could search the internet for the part number and see which other retailers might have one. I did replace the spur gear with this metal one from Hot Racing. https://www.ebay.com/p/1540500821?iid=165913360017
Since this part doesn't seem to be available anywhere has anyone used an alternate setup for the center drive shaft on the ECX Ruckus?
Looking for the same, need a 230mm dog bone drive shaft from another kit, did you have any luck in the end?
Anyone got any ideas or suggestions on kits, that are not discontinued, with similar sized main drive shafts?
