Hi I’m only going to run 2 s or the nickel batteries that came in the kit hopefully the trans will last or like you said time to upgradeyou're probably going to want to upgrade the transmission to metal gears. part # ecx 9001. the plastic gears are pretty tough but not that tough.
that thing is gonna rip! please keep us posted
yea on nimh they will be fine but even 2s it's just too much speed for those gears I'm afraid. 5700 kv is going to rip lolHi I’m only going to run 2 s or the nickel batteries that came in the kit hopefully the trans will last or like you said time to upgrade
It’s a new motor and esc I had it so I will try it out thanks
Hi so I ran the new motor combo and I need to gear up for tq so smaller pinion and bigger spur I’m running stock gear what do you recommend and we’re to buy thanks
| Application Guidelines: | For 2WD short course trucks on 2s LiPo and geared conservatively. 1/10th 2WD Stadium trucks and buggies on 2s for bashing and limited runs on 3s with conservative gearing. Great for 1/10th scale on-road cars for 2s and 3s use. NOT for use in 4WD short course trucks. Please refer to our Gearing Chart for recommended motor, battery and gearing for some of the more popular vehicles on the market. |
| Wheelbase | 11.6 in (294.6mm) |
| Front Track | 12.9 in (327.7mm) |
| Outer Diameter | 4.3 in (110mm) |
| Product Width | 12.9 in (327mm) |
| Rear Track | 12.9 in (327.7mm) |
| Product Weight | 3.44 lbs (1.6kg) |
| Length: | 17.5 inches (445 mm) | |
| Front Track: | 12.25 inches (311 mm) | |
| Rear Track: | 12.25 inches (311 mm) | |
| Weight: | 59.6 ounces (1.69 kg) | |
| Height (Overall): | 7 inches (178 mm) | |
| Wheelbase: | 11.375 inches (289 mm) |
Now into make a wheelie bar setup any help?
