This is the kind of spur gear i have. im looking for a pinion gear that is mod 1 the pitch i was told was 48 thanksYou don't want 48p, that is different than mod1 (48p has tiny teeth). Depending on the size of your motor shaft, Robinson Racing makes many mod1 pinions that are 5mm. They also sell a reducer sleeve from 5mm to 1/8 inch.
http://www.robinsonracing.com/catalog/5mm_pinion.html#12xx
Mod 1 does not equal 48p. You want mod 1.
Copy/ pasted from another site:
Metric VS. Standard
1.0 module-referred to as metric 32 pitch is actually a standard 25.4 pitch.
0.8 module, is the same as 32 standard pitch
0.6 module-referred to as metric 48 pitch is actually a standard 42.3 pitch
0.4 module-referred to as metric 64 pitch is actually standard 63.5[/QUOTE so this wouldn't work
Metric VS. Standard
Metric VS. Standard
Ok thanks , yeah I've been misdirected from them before on some tire sizes but they ended up sending me a free set of tires for there mistake . so what should i do about finding the right pinion . .The problem I'm seeing here is they are saying a mod 1 gear is 48 pitch... there is no such thing as a MOD 1 48 pitch gear. I'm sorry... but Horizon Hobby support is wrong. MOD 1 is not just simply the name of the gear, it truly does refer to the pitch. The information @X has provided is 100% correct.
Probably have to the truck to the LHS to see what we cand do! thanks for the response and guidanceOk thanks , yeah I've been misdirected from them before on some tire sizes but they ended up sending me a free set of tires for there mistake . so what should i do about finding the right pinion . .
The ruckus and torment seem to both use mod 1 spurs. I would get the ECX/dynamite pinion gear pack. It's $12 on Amazon.
https://www.amazon.com/gp/aw/d/B003KSKQL2/ref=ox_sc_saved_image_6?ie=UTF8&psc=1&smid=A2HG7KNUEK3HVB
I understand. I believe those pinions will work. In a few weeks I will try on my stock truck and let u know if I break anything.Those are 48p.....he needs Mod1.
What's the worst that can happen. I buy a new gear and slipper? New motor? I am not afraid.
Also from my understanding the mod1 and 48p are very very close.
Looking at a picture, you won't be able to tell the difference in pitch esp if one has more teeth than the other. You need to understand what pitch means. It is the space between the individual teeth. Can you measure that in any of your pics?
this is probably the best pic I have found...you are correct...my previous research is wrongIf you would like to intentionally damage parts, feel free. Who am I to stop you?
You should probably look at @wizardwerx8 picture as well. He is showing you the 48p kit you are referring to next to a mod1 spur.
