Anybody else build scale trucks from the tempers?
What all have you done to your Temper, besides the obvious exterior mods?
It's got a full frame, new links, cut shocks up front,no springs, been to busy to install the proper fronts,rear shocks are aluminum, 2 piece rims, huge offset, aluminum driveshaft tubes, u joints are now steel with pins,rc4wd tires, savox servo,custom wound 100t motor,7.4 lipo with cutoff,aluminum steer links,swapped to losi transmission, aluminum trans skid,can't recall the gear ratio now, aluminum gears, converted upper link to run off top of axles, damn thing even has lil brakes on the wheels lol
