6packcrawler
Hey everyone ECX temper 18th scale stripped out ball joint screw. Ordered all aluminum steering components. Does factory screws work or will I need to purchase somewhere any advice on the conversion?
Also the purchased screws are your aka ball joint screws .start both leave both loose. Tighten one down all the way then back off qtr turn then tighten other one down all the way and check first one this prevents binding issue I ran into during the processThanks for sharing, I'm sure I'm going to be doing this upgrade so it's good to know up front.
