ECX temper aluminium steering knuckle install extra parts needed?
6packcrawler
Hey everyone ECX temper 18th scale stripped out ball joint screw. Ordered all aluminum steering components. Does factory screws work or will I need to purchase somewhere any advice on the conversion?
These are the extra parts I needed and worked perfect along with a couple of longer screw from the complete hardware package got them installed.
Thanks for sharing, I'm sure I'm going to be doing this upgrade so it's good to know up front.
Also the purchased screws are your aka ball joint screws .start both leave both loose. Tighten one down all the way then back off qtr turn then tighten other one down all the way and check first one this prevents binding issue I ran into during the process
