Front end
Briguy
Virginia Beach
My son was nice enough to force me to rebuild the front end of my 2wd ruckus. I want to fix the sloppy steering while I'm in there what do I need ? Staying inexpensive if possible. Tia
Rpm servo saver eliminator. Tightens it right up. Just keep the plastic servo horn as a place for it to break in a bad crash.
I gotta get one of those.. Love the design of the RPM servo saver eliminator. While you're there as well, and you have some extra cash, might as well replace those A Arms with the RPM versions, and the front steering blocks with the RPM versions as well. Keep in mind, if you swap out the steering blocks you'll need an 11mm bearing. The stock bearing is 10mm.. RPM says that the 11mm bearings can take more punishment.
