14mm Hexes
Hey guys i have slash steel axles on my ecx amp and i want to convert to 14mm, any ideas? I have an idea of fitting these possibly because they are cheap, and the recess on the inside looks almost non existent so it would be very easy to open up to fit the slash axles.
https://www.amazon.com/Hobbypark-Aluminum-Granite-Replacement-AR310871/dp/B08LDNXRLK/ref=mp_s_a_1_4?crid=640BQS6FCRHP&keywords=14mm+wheel+hex&qid=1643152794&sprefix=14mm+wheel+hex,aps,667&sr=8-4&th=1&psc=1
Why would you want to use 14MM hexes? That would limit you to Arrma wheels and tires, since noone else uses a 14MM hex.
Poseidon2025, if you go to 14mm hex, on your AMP, you will have to go to 6mm axels. You can buy, online, 14mm hex with a 5mm bore to fit your stock axials.
