Diff gears for 1/18 4WD Ruckus
☆The kit fit!!!!!
Carisma
GT14 B Gear Diff Conversion Set​
Part #: 15316 actually fits!
To be clear the diffrential conversion kit fits inside the ECX diffrential housing.
If you have an ECX Torment or Rooster 1/18 and your diffrential internals have turned into their Infamous melted butter and you cannot find the COMPLETE GT14B DIFFRENTIAL then get the GT14b diff conversion kit, it has the internal bevel gears in metal, also grab the cheap set of diffrential seals as mine ripped easily when taking apart. I was not able to use the original stainless ecx shims nor the Two brass shims from the Carisma kit, but ONE brass shim did the trick perfectly.
My ring gear and Propeller shaft bevel gear show no signs of wear so I am hoping this will be a great fix for a great little truck.
I also added Tamiya tt02s carbon fiber shock towers. The truck handles fantastic and the diffs sound great! Im running a 2858 5900kv motor and a HobbyKing Car-45, 45amp ESC on 2s & 3s with original gears and it werx a treat. No problems...yet, after 6 runs.
Hope this helps anyone, cost was nominal and Carisma shipped to the states cheaply and VERY FAST!
To be clear, you put this on a 1/18 Ruckus?
