Drive shafts
I have a torment and I had the same problem with the plastic ones but I went with the hot racing steel shafts.... I do not recommend... they look nice but get stuck in the bearings and they get extremely off balance and tear the diff output shafts out... maybe mine were faulty who knows....
good luck
DirtHead, the Hot Racing driveshafts are no longer available and I don't know why. I have them on a few of my RC's and they are awesome. I have used these, from RCAWD, and they seem to be working well. The only drawback is, you will only be able to use a 12- or 14-mm wheel hex wheel mount with set screws, as the axel doesn't have a hole for a drive pin. That's probably a plus, as when you pull the tire off, the hex will remain on the axel. Hope this helps you somewhat.
