kruzracing169
- Location
- ND, USA
Up for sale.....
Used RTR, ECX 1/10 scale 2wd Boost buggy.
(All you need is batteries and charger)
*I ran a Turnigy Ultimate 2S2P Lipo 4600mah shorty battery*
This is setup and tuned for the track!!!!!
Everything is fresh!!!!
*tires are used AKA, still good for clay and smooth surfaces.
What is put into this buggy is as follows;
-Brand new Hobby King radio and receiver.
-T-Bone racing front bumper.
-Titanium turnbuckles front and rear with RPM ends.
-Front and rear aluminum shocks with Tin shafts and upgraded stands off shock mounts.
-Front Hot Racing steering knuckles.
-Front RPM C-hubs.
-RPM servo steering saver.
-Hot Racing aluminum steering horn.
-Trackstar buggy mini servo, shaves off weight.
-Trackstar 17.5 brushless sensored motor and 80amp *Blinky* ESC. (Tuned for 5amp times motor, with 5mm bullet battery plugs).
-RPM gear saver/tranny cover.
-Team Associated spur and pinion gears.
-Body is a custom molded Lexan, made for the ECX boost, provides extra venting and room for larger side mounted ESC.
**(I will have a NEW fresh body made, just using existing for visual)**
I built this buggy over the summer for my daughter to run at the track. It was ran 1 weekend over labor day, otherwise has say on the shelf. Needless to say, she is not interested.
I WILL SHIP ANYWHERE IN US.
-Front RPM C-hubs.
