Help with pinion/spur alignment
Jakenew101
I’m replacing the stock spur & pinion gears on my 2wd 1/10 Ruckus. Purchased Hot Racing 17t 48p pinion, & 87t 48p spur. Problem is that the gears are not in alignment with each other. Should I put washers on the back side of the motor mount, in order to pull the pinion gear in more? Any & all help is appreciated.F2AFA322-5185-4E72-A346-39E0D1CAAAEC.jpeg23A24843-A581-4B05-8199-7DCEFCB27716.jpeg
you could also use a splint like a piece of plastic or metal to space the motor and pinion gear. if not then you can use the ecx buggy motor mount, it has a adjustable slot for the motor screws.
