metal or plastic gears
james
Hi everayone im thinking of upgrading to a brushless 4000 kv motor for ecx amp db, do i need metal gears, will the plastic gears strip?
My son is still on plastic gears. Admittedly it’s a Boost buggy not a truck and running 2s on something like 3500kv.
Why not try it?
Depends how much mechanical sympathy you give your truck I suppose....
Metal trans gears for sure. Easy to install, just use a decent grease on them. You might as well change the bearings as well.
