Paddle Tires on ECX AMP
23lrupp
I have an Amp with the Onyx 4000Kv motor running on 3s 5000mAh LiPo. I am wanting to get some paddle tires for it to hopefully hydroplane, and I am wondering what you guys recommend, and also, is it possible to hydroplane with a 2wd vehicle? I've never done it. Thanks!
Lephturn
Maybe if you put snow skis on the front? Doubt it’s possible with 2WD otherwise.
What pinion and spur gear?
Steve g
Massachusetts
I bet its possible. A dirtbike can, which is much heavier with similar or even slightly less rubber contact. Just have to go fast enough and stay on the throttle.
