Good answers so far = a bit faster especially at end of charge. If you have stock electronics I doubt the esc has LVC = low voltage cut off which you must have or you'll ruin your battery--ask me how I know! Lithium packs cannot run out all the way like Nimh can and if you do it even once you can really damage your pack. LVC in the esc will cut off power when your pack gets to the danger point. Problem with the ECX systems they combine ESC and receiver so if you want to upgrade you must upgrade both.
Things to consider; The Amp is a great truck but to keep the price down many things are not strong. The Amp has weak steering and a faster truck can use stronger steering = metal gear hi torque servo and RPM servo saver eliminator 2--The motor over heats in 5-10 minutes = brushless motor. I tried to attach list but couldn't so here's a list;
--SERVOs The stock steering servo seems a bit under powered, to remedy simply upgrade the servo to something like these metal gear high torque. This is the first to get as a more powerful motor will need stronger steering.
--Futaba $36 --> Futaba S3305 Standard High-Torque Servo with Metal Gears
http://tinyurl.com/jkn3rbx
--Savox $35
Savox-SW-0231MG-Waterproof-High-Torque-STD-Digital-Servo http://tinyurl.com/z4dssrh
Hitec HS5645MG -- $38
--Inexpensive Servos -
Power HD 1501MG,
MG996R
**--I would also consider beefing up your steering with this -->
http://tinyurl.com/gwvolcv
Install RPM Steering Thread -->
https://ecxforum.com/threads/steering-linkage-design-issue.396/
THIS Kimbrough Servo Saver
http://kimbroughracingproducts.com/store/index.php?dispatch=products.view&product_id=29909
On Amazon →
http://tinyurl.com/gtocku4
Bearings - The bearings in the ECX AMP leave a bit to be desired, such as being sloppy and/or not very reliable. The easiest solution would be to pick up a
FastEddyBearings ball bearing kit -- $14
If you're building the kit version of the ECX AMP I would buy these bearings at the same time and save yourself the work of going back and replacing the stock bearings.
--RPM Upgrades RPM is a great company making stronger parts for many cars incl Amp. I've used many of their things but not many for the Amp yet. If I break any Amp parts I will most likely replace it with RPM if they make that part. Usually if I break a part I order two but with RPM that is not necessary as it will probably not break again. Select 'ECX' and '2WD Ruckus' for Amp parts on RPM site as the trucks share many parts.
http://tinyurl.com/jkn3rbx Amp aftemarket mods below at end--Many RPM
--How to fix AMP steering linkage design issue
https://ecxforum.com/threads/how-to-fix-amp-steering-linkage-design-issue.422/
--Brushless Motors
--I have this one and like it*** This and the Orion are a special/weird new thing where the ESC is combined with the motor so it does not need to be soldered and uses less space--> Tazer Twin BL MOTOR/EXC Dynamite 3000KV
https://www.amainhobbies.com/dynami...rushless-motor-system-3000kv-dyns1450/p474342 ***But it's too fast and needs a transmitter with EPA = End Point Adjustment to dial down the speed a bit for kids.
--Similar-->I’m interested in this one but haven't tried it yet but Orion is a famous high end company
Team Orion dDrive 540 4-Pole Sensorless Brushless Motor System w/Deans (2700kV)
http://tinyurl.com/z3y2svk
These below are traditional separate ESC and motor systems that need to be soldered
--Very good Brushless motor system--> **CASTLE 3800 amain $106→
http://tinyurl.com/zlmzvpw
Hobby King is an upstart Australian company that came on the scene several years ago with cheap stuff that has gotten to be very good in some cases and has changed the industry.
Hobby King Brushless system proven by a friend with a Marin RC summer camp (ask me!) that has 6 of them running a lot 21.5 Turns = fast but not too fast-->
http://tinyurl.com/huzbo8f
Nother = faster = 17.5 Turns-->
http://tinyurl.com/zcnbbws
--Radio These have EPA
I have one hooked up to my TLR 22 and will have it next week Tx & Rx-->FS-GT3B $50
http://tinyurl.com/gllxyhr I researched and read an article on various models of this level of radio--I like it so far. The programming is cool and educational.
--Futaba--perhaps more reliable but no screen or programing -->
http://tinyurl.com/j3gcfpd
