looking to change stock tires on my 2wd ruckus
stock have 5" diameter
if i switched to a tire with 4.7" will i need to adjust size of pinion?
currently stock 24T (brushless ruckus)
and/or do i just get spur gear with less teeth to make up for lost speed?
Those are 17 mm hex they wouldnt fit on ecx carshow about the hatchets by duratrax?
Duratrax usually has softer compounds and probably won't last long especially on cement of any kind.according to duratrax they have some in 12mm hex
not sure how they would hold up on pavement and off road
so trenchers are a good compromise for off road while still being somewhat decent on pavement?
How do you maintain tires?They are a little expensive but they will last a long time if maintained well enough.
Check the beads and make sure they are glued well and they do sometimes come loose on almost any wheel.How do you maintain tires?
Yea I wouldn’t be surprised if there isn’t many 1/10 scale tires the same diameter of the stock ruckus tires. I dont know why but the torment has a weird issue like that too. It’s stock tires are a lot smaller than actual SC tires. The ruckus is opposite it’s tires are much bigger than after market. It does seem like ECX makes the tires kind of cheap and super hard compound I don’t know why but reality? possibly.I run Trenchers since Christmas in my 2WD Ruckus. Awesome traction and looks. A bit smaller in diameter than stock tires, and I'm not sure if they're also lighter. I haven't changed my gearing yet, in my opinion is not necessary, though I have a Robinson Racing pinion ready if needed.
