OK thanks. im new here its so cool and everyone is nice!I use Proline bodies for the most part. But best thing to do is get the dimensions of the truck and/or current body and see what matches its measurements.
I wish someone could tell me he answer! I'm new here, u too?Do you think the axial scx10 II Cherokee body will fit on the amp?
Because if they do they look real good and you can get both painted and non painted
Hi, this body fits pretty well, it is for the Traxxas Rustler which has a very similar wheel base. You might have to deviate from the wheel cut out lines a little .
https://www.amazon.com/Illuzion-201...=8-1-spons&keywords=illusion+clear+body&psc=1
Probably yes, but I dont think it would be noticable with such a slight change. If you use a metal body, the motor probably might burn outDont going from a stock body to a hard body add weight and possibly slow it down ?
This method would work for the jeep body as well.
This Is my new body after I get the rear mount done.I would like a body but not from ECX!
I'm gonna order It Fri and will let you know how It comes along.Have you gotten a rear body mount if so can you give me the link to it and tell me how you got it on.
