PhillyRcBoyz
I'll try later on todayLooks the part. Should be interesting to see how they hold up. What setup are you running?
"Cool" I ran into that problem as well, with those lil pins. Now I use longer pins that goes all the way into the other side of that hole.I've fitted these to my boys amp as he kept snapping the original ones seemed fine and worked well for the half hour we were out b4 he stripped his diff lol one thing I did notice was when I was fitting them the grub screw that is inside that holds the pin in was not fully tight and would have fallen out on the first outing if I hadn't of noticed it
