ECX Temper Picture Gallery
What servo should I use? I have burnt out two of the savox ones.
Is it user error and I’m locking up my wheels and still trying to turn? Should I adjust my steering to not turn so much to avoid?
I used a high torque from Amazon. Depending on which model Temper you have, you may need to trim a little of the rear of the servo arm or do like I did and completely flatten the rear of the metal servo arm provided. It’s 30 sec on a sander or 1-2 minutes using a file. I then rounded the front edge of the servo arm. Also was on a sander or using a file. I also used VC-3 on all the bolts to keep them from coming loose. Here is the link to the servo I used:
https://www.amazon.com/gp/product/B073M8QT1S/ref=ppx_yo_dt_b_asin_title_o02__o00_s00?ie=UTF8&psc=1
Nice!
Don’t order the hot racing air shocks with internal springs. I’m not too happy and having a hard time keeping the left from torque twist. I added fuel line in there as well but still not helping much
turn your motor and tranny crossmember around a hundred eighty degrees it'll help a lot with a torque twist
She is coming along!! Love this thing!! Servo horn is temporary as my old metal one is not fitting lol!!20190424_212840.jpg
So I made my temper a 1/10 scale mega/mud truck
