kruzracing169
- Location
- ND, USA
This is VERY good. I love build threads!I would like to start a post on my journey through the upgrades. I want to capture everything I do. Is it good or bad?
Thank you! I take pride in my work, so it means a lot when someone throw's a nice comment like that.This is VERY good. I love build threads!
By the way you've got a great looking ECX Temper!
Rear hubs? If your trying to pull the axles out, you need to take the whole differential apart. The inner bearings hold them in, when sandwiched between the two halves of the differential.Any advice on seperating the rear hubs from the axles?
I have the doomsday 390 on mine and keep stripping the spools please let me know if you find an aluminum one for purchase.
I just meant do you think the front spool will be stripped out shortly after installing the aluminum Spool in the rearNo problems, the shafts slide right into the spool. I’m not sure what you’re asking about spinning out the front one?? I blew out my rear so I just ordered 2 right away and did them both.
