Keep in mind replacing the ECX AMP speed controller will also require you to change your radio system as the AMP's receiver and ESC are one item.
That said, not knowing your price range - if you wanted to go cheap you could go with an HPI SC-3SWP ESC which seems to support all your requests.
So far I have added a 6000 mah 2s LiPo, have the low voltage alarm on top of the battery holder and have replaced a spur gear already. Lol I played with the gearing by adding 2 teeth going from an 18 tooth pinion to a 20. But ended up liking the stock better.
Very nice!! my next step is going LiPo also. Are you still running the stock brushed motor and what was the run time on the 2s?
Still on stock motor LiPo makes a huge difference, I'm getting over an hour running the truck wide open. Tested today! May be going brushless soon lol
What are your run times w/7 cell and brushless ? I just ordered a brushless motor/esc combo but sticking with nimh for now.Wow!! An hour that sounds pretty good to me. I'm definetly going to LiPo I have a brushless system not sure if I want 2s or 3s though. Did a speed run with 7 cell nickel got up to 33.6mph
What are your run times w/7 cell and brushless ? I just ordered a brushless motor/ESC combo but sticking with NiMH for now.
Sorry meant how long does the 7 cell last?But yes that's a nice improvement over stock with nimh, that would be plenty for me lol.Fastest I had it going was 33.6mph. Battery wasn't fully charged though so maybe would have went faster not sure. Still running stock gearing prob won't change. Unless it will make it faster lol!!
So what brushless system are you using? Motor and ESC?and that's crazy you're getting that speed with the stock pinion and spur you could go a lot faster if that's the case. 87 tooth spur and 18 pinion is like 4.83 rear ratio.
Sorry meant how long does the 7 cell last?But yes that's a nice improvement over stock with NiMH, that would be plenty for me lol.
I'm using the dynomite tazer 4000kv and 45amp ESC kit. Thanks for the info I guess I'll be shopping for a new spur and pinion then. Lol!!
So are you still running stock Trans all plastic with brushless? If so that slipper clutch is doing one hell of a job
I think at this time the first thing I will do is find a 2s LiPo, add a voltage meter/alarm because the stock ESC does not have a low voltage cut off. Then I may swap out the 20turn 540 for the 15 turn 540 I believe my stock ESC should support this. Once I find a radio that I really like I'll cross that bridge.
so if I got this right the low voltage alarm just gives you a audible sound to let you know its time to stop and recharge the batt pack? And does not cut out the battery from circuit? Is it loud?So far I have added a 6000 mah 2s LiPo, have the low voltage alarm on top of the battery holder and have replaced a spur gear already. Lol I played with the gearing by adding 2 teeth going from an 18 tooth pinion to a 20. But ended up liking the stock better.
...best 15t brushed replacement...
