joceton
Hi folks. Looking to get some thoughts on some ESC settings to prevent truck breakage. I am running the 1/10 4-Pole ESC/Brushless Motor Combo, 4000Kv: 3.5mm Bullet, EC3 with a 2S lipo 5000mah battery. I have posted a pic here of the ESC settings, the only thing I've changed so far is the Low Voltage cutoff, I changed it to 3.2V. The reason I ask is my first run with it, the punch is flipping the truck, and it seems as if i tore one of the rear suspensions arms clean off the pin. I suspect the punch had something to do with this. So looking for opinions on what the best settings for this ESC would be so I'm not replacing parts every run.
Thanks
Thanks
