Castle 3800kv motor?
Kaden
Would the castle sidewinder 3800kv motor and esc work good in the amp, what kind of speed?
I’ve already got new reciever and remote.Will also be getting a 2s lipo.
Could depend on gears what size pinion
Not could, will. ?
I just hit 68 kph with my Amp on 3S with a 23 tooth pinion amd the stock plastic spur. Metal gear set and larger wheels/tires so my final drive is definitely higher than it was with the stock wheels and tires.
I have the Castle sidewinder 3800kv in my AMP. Pretty much the perfect motor for this truck in my opinion.
Clocked it at 34mph with obviously not stock gearing, but still drivable (which means it wouldn't over heat and cook after 5 minutes of driving).
Very powerful and quick motor.
Kaden, I've run the 3800kv and 4600kv in my Amps and have not had any problems. I do install high velocity fan's on the motor to keep things cool. The fans run on their on separate dron battery, 7.4v @ .800 to 1mAh. The batteries are also switched. I also run Pro-Line Trenches, so we been clocked at times of 50 to 60 mph. Below is my shop were i do all my mods. The Amp is a great truck to upgrade and as you can see the upgrades are endless. 20200415_161201.webp20191207_163903.webp20191231_154135.webp20200522_171114.webp
