1/18 Ruckus Metal Diff / Servo
F123
Hi all
I have a 1/18 Ruckus i found a verry good upgrade setup for Brushless drives great with this.
Only problem is the Differential everything else lasts good.
I searched Internet for Metall upgrade and i found nothing like plug and play for only Diff.
I don't like to work too much on it to fit, because i don't like to take care about the cars, so everything which gets killed should be fast to replaced. At the moment i exchange more often Differential which costs the usual 25 Euro. I would have no problem to spend 50 if the diff lasts afterwards. Found someone a fast to replace Solution?
Greetings
Frank
If someone is interested i found also a plug and play mini servo with metall gear and whaterproof where everything fits 100 percent to stock. If someone is intestet to know i would tell you by PN the Servo.
The carisma diffs are direct fit. I have seen threads here and I bought some but haven't installed them yet
This is true..... they have discontinued the ring and pinion of that diff assy. So you can have metal internals. Looking into lc racing diffs rn.
