i just bought the temper and wondering does your have torque twist and is it very loudPretty much what he said! Do you want to go slow (and the Temper is SLOW) and steady over rocks and uneven ground or fly over the dirt and grass. And I also agree that the temper will probably last longer without need of repair simply because it's slower and doesn't wreck as easy. I own a Temper and love it. One battery lasts for ever (ok 30-45 minutes easy).
I also own a faster off road truck and I love it too, one battery lasts about 15 minutes.
So it really depends on what you like to do.
Oh yeah, it's loud!i just bought the temper and wondering does your have torque twist and is it very loud
so i pull the spring down and that little ring then what?Oh yeah, it's loud!
And stock it has horrible torque twist. That's one of the first thing everyone works on when they get a Temper.
There are lots of fixes but for now, slide the top of the rear left (drivers side) spring down, there is a little ring at the top of the spring, take that down too, slide it all down and hook it on the bottom of the shock body.
It will shorten the spring and create more tension on that side to help compensate the twist.
Search around the forum here and you'll find many different methods.
Enjoy!!!
two zip ties on every shock?I used two smaller zip ties stacked to hold the spring collar down instead of wedging it. I did all four shocks and the torque was greatly reducedView attachment 1644
