One of my 3s battery balance leads pulled out while driving.I've never had an issue honestly. As long as you pull on the connector, not the wires, you shouldn't have issues.
If they have pulled out, you've likely ripped some plastic off the inside of the connector and possibly bent the spring retention on the pin. You'll have to assess the damage and replace whatever necessary.
