Balance wires
KyleRC
Is there any good way to prevent balance wires from pulling out?
I've never had an issue honestly. As long as you pull on the connector, not the wires, you shouldn't have issues.
If they have pulled out, you've likely ripped some plastic off the inside of the connector and possibly bent the spring retention on the pin. You'll have to assess the damage and replace whatever necessary.
One of my 3s battery balance leads pulled out while driving.
Best to zip tie everything you can. I had to scrap a perfectly good ebay ESC because a battery lead broke off, and then I butchered it trying to solder on a new one. Lesson learned, no more overlong wires flapping around under the body :)
