Relatively new Amp MT is making a noise each revolution. Seems like a click or scrape. Pulled the wheels off and then the cover over the ring and slipper clutch. Pinion and ring gear look fine. Motor is not making the noise. With motor stopped if I turn one wheel and the other turns I don’t hear or feel anything. When both wheels turn the same way I hear it. Seems like something in the gearbox between the ring gear and the teeth on the diff.
Any suggestions? Looks like I have a bigger tear down job to get this all apart.
Since I have the motor off this might be a good time to look at a bigger one. I don’t want to go brushless yet but maybe I need to look at metal gears?
How tight should the pinion be against the ring gear?
