Joshnewb
started with buggy kit, but wanted it wider and longer
basically a turbo scorpion with buggy body, including Turbo Scorpion shocks
still have all original parts/decals/manual that came with buggy kit
tamiya gunmetal metallic flake, and black, then used spray on outside to make hood/rear spoiler matte black
HW EZRun max10 combo (60A esc/4000kv 4pole)
Xpert 3431 brushless servo (Fast/metal gears)
2.2 wheels, AKA red closed cell inserts, Proline holeshots front/blockades rear, spare set black 2.2 rims
Kyosho universal shafts not installed (backup for when stock break), 12mm rear hex adapter
Kyosho lightweight steel 28t pinion (installed)
Lunsford Punisher and XRay spring steel adjustable turnbuckles
Kyosho CNC aluminum motor mount, CNC arm shaft block, CNC front caster lock
setup, never ran, battery i used won't fit in battery box, so all i did was make sure everything worked
esc not taped down yet, never even been outside the house
receiver/radio not included (do have Kyosho Syncro 3channel Rx/Tx $25.00 more)
$550?--make an offer
