Pinion Keeps coming off of motors shaft.
DemonTime
I have just installed a new Pinion and after high speeds my car begins to make a loud noise then it will just stop moving but I still can move the two front wheels. Do I need to glue the Pinion down by the 1.55m screw? I am very confused thanks.
Did you use Loc-Tite on the screw in the pinion? The screw can come loose fairly easily.
If you put just a small dab of blue thread lock on the set screw it will take care of that problem.
