Did you use Loc-Tite on the screw in the pinion? The screw can come loose fairly easily.I have just installed a new Pinion and after high speeds my car begins to make a loud noise then it will just stop moving but I still can move the two front wheels. Do I need to glue the Pinion down by the 1.55m screw? I am very confused thanks.
What is that I just got into RC yesterday.Did you use Loc-Tite on the screw in the pinion? The screw can come loose fairly easily.
https://www.amazon.com/Loctite-Heav...ocphy=9005776&hvtargid=pla-350863460111&psc=1 It is a type of glue for metal screws. You only need a drop or two. If you use too much, you will need heat to get the screw out. Dont use it in plastic though.What is that I just got into RC yesterday.
Okay thanks do I let this dry over night or for a few hours after?https://www.amazon.com/Loctite-Heav...ocphy=9005776&hvtargid=pla-350863460111&psc=1 It is a type of glue for metal screws. You only need a drop or two. If you use too much, you will need heat to get the screw out. Dont use it in plastic though.
The instructions say sets in about 20 minutes, fully cured in 24 hours.Okay thanks do I let this dry over night or for a few hours after?
If you put just a small dab of blue thread lock on the set screw it will take care of that problem.I have just installed a new Pinion and after high speeds my car begins to make a loud noise then it will just stop moving but I still can move the two front wheels. Do I need to glue the Pinion down by the 1.55m screw? I am very confused thanks.
