I dont have a pinon gear to fit my spur gear the spur gear is a 48 pitch on my tornmemt 4x4 . its a mod 1 spur i need to know what size or model number number from any manufacturer that will work.can you post a picture of the bad mesh issue?
Its a 48 pitch spur gear mod 1 with a 45 tooth. im trying to use a castle creations sct brushless motor with a 1/8 shaft . just need a pinion to get it running aginI forgot to ask how many teeth does you new spur gear have? If it's significantly larger or smaller than your previous one, you would have to match it the opposite with your pinion gear... for example, I run a 71 spur and 31 pinion on my pro-stock 17.5 buggy. But my mod buggy is running a 81 spur and 19 pinion.
No im not i figured it out thanksI think he's trolling for responses because 48 pitch, 32 pitch and mod1 pitch is not that difficult to wrap your head around.
