CumminsFan
AluminumWhat metal did you use for the frame?
I just reread you op. Apparently yesterday I couldn’t read at all haha. Thanks!Aluminum
No problem lolI just reread you op. Apparently yesterday I couldn’t read at all haha. Thanks!
I would, but I'm still waiting on the new motor, there isn't one in it as of right now, but i will when I'm done!Nice looking build, if you have a camera, you should post a little clip of it climbing![]()
https://m.ebay.com/itm/Trinity-EPIC...:am8AAOSwZqZaFF1N#wrapper-reviews-btf--parent not sure of how many turns it has, but it is brushedWhat motor is it? Brushed 27t?
Thanks, I might have too, I'm probably just gonna run it untill it breaksHave you swapped out the differentials yet?
You're going to need to with those big tires and that hot motor.
Get the metal ones for a Redcat Everest 16 they won't strip out like the stock plastic ones do.
They are what I put in my rig http://temper.loosenuts.com/2017/03/rebuilding-differentials-ecx.html
Well my build is finished for now. Roughly 3 and a half inches of ground clearance, 100mm shocks, and a 280 motor. Looks about twice as fast as stock. To mount the shocks i used a 1 inch extension off the frame acting as a shock tower. Still gets good flex and torque twist is gone. Seeing it drive put a smile on my face lol. Can't wait to test it out.When did you get your temper? I open up my gears and they were metal already in the in diff box. I just added some red sticky grease.Have you swapped out the differentials yet?
