kruzracing169
- Location
- ND, USA
Patience......I wanted to provide a close-up on the unboxing.I wish you showed it performing
Next release will be the stock review. I'm running it this weekend on natural terrain.
I will definitely get my video done this upcoming week.
how many turns is the motor on thatPatience......I wanted to provide a close-up on the unboxing.
what kind of battery does it have and can we see some footage of it on flat loose ground doing donuts or Full ThrottleHere you go! Just finished up the video editing last night. Hope you enjoy! Overall, I am very pleased with this RC.
Please Like, subscribe and comment.
If you want to see anything different, or pointers, let me know.
I will have more content as this RC gets upgrades.
I can do that.what kind of battery does it have and can we see some footage of it on flat loose ground doing donuts or Full Throttle
I take it the temperature Gen 2 has the axles of the barrage doomsday and Link bars does the Gen 2 temper also share the same motor as the Doomsdayhow many turns is the motor on that
main reason I'm so interested is I have a temper gen1 and I have also bought a barrage doomsday and get it it to use parts for the temper I used to axles the bars and the motor and transmission but I had to make my own custom transmission mounting bottom plate to make wider for the Doomsday motor right now I'm stuck with a non-operational gin 1 because I'm having problems with stock rear axle shafts being too weak where the set pin is with a 4 mm diameter having problems finding a machinist tool make me some 5 mm diameter at the set pin and also due the larger motor and more power having problems twisting axle shafts inside this spool and I need to find an order some metal upgrades for the spool all-in-all I've spent a lot of money on this little car and would like to keep it on the cheap side because I've already upgraded the battery that you CS the shocks kitchen scale and the servoI can do that.
main reason I'm so interested is I have a temper gen1 and I have also bought a barrage doomsday and get it it to use parts for the temper I used to axles the bars and the motor and transmission but I had to make my own custom transmission mounting bottom plate to make wider for the Doomsday motor right now I'm stuck with a non-operational gin 1 because I'm having problems with stock rear axle shafts being too weak where the set pin is with a 4 mm diameter having problems finding a machinist tool make me some 5 mm diameter at the set pin and also due the larger motor and more power having problems twisting axle shafts inside this spool and I need to find an order some metal upgrades for the spool all-in-all I've spent a lot of money on this little car and would like to keep it on the cheap side because I've already upgraded the battery that you CS the shocks kitchen scale and the servo I meant ESC and servo and shocks to 10 scale
Just found out about these yesterday with my buddy who owns an original Losi 1/18 MRC. I'm surprised I haven't already ordered one, we both will be buying Lol. Really wish the Gen 1 temper would've been designed like this, but they didn't have the barrage at the time either.
