These are all I can find in stock anymore
https://carisma-shop.com/products/gt14-b-gear-diff-conversion-set
Those should drop right into the stock diff cups. Unfortunately I cannot find the rest of the diff parts. It would be nice to find the crown and ring gears.
Other than that you are stuck with the stock diffs unless you can somehow find a set of the Carisma diffs or find a set of diffs from the Losi Mini 8ight but with those you have to make your own driveshafts.
I tried the diffs out of an LC Racing EMB-1 they are just a tad too narrow, you would need to buy some shims to get the diff to center in the housing correctly but the ring gear won't attach to the slipper shaft and the plastic Ecx ring gear seems to be a different pitch that the LC Racing.
I've been dealing with the mess that is the 1/18 Ecx Ruckus for 7 years and have unsuccessfully tried so many different diffs in this thing.
The worst part is Horizon won't acknowledge that the diffs are a problem they insist the diffs are just fine...........
With the way things are going for Ecx I do not foresee anyone ever making metal diffs for these. Hot Racing stopped making parts for this platform and they do not have plans to make anymore so what is in stock now is basically all that is left. They are even stopping production of parts for the 1/10 platform.
