I tried a Lipo 7.4 2s 180 mah the same one used on Losi crawler that my hobby store recommended ran great the first time I put it in and then the second time around after charging it the ESC started to get hot and what notified me about it was that I was close by it and smelled like a plastic hot burn smell and at closer inspection the ESC was hot but not burning hot and the smell was coming from it so I immediately stopped using it because I didn't want to burn it up so I can research some more and see if anyone else encountered this problem too? and if so is it still safe to use without burning up the ESC? I ran it for 5 minutes crawling on a foam course a made and indoors. Any thoughts? ThanksHave you tried to rebind it? Next hard dragging spot is in the trans bushings, some of the cases are thicker than others it seems and pinch the bushings in there a bit, loosen the case screws on both sides and split the cases a hair, if that loosens it up then it's easier to pull the bushings and lay them flat and sand then down a skooch. Also the stock battery charger doesn't give the battery full voltage. Only about 80%
They run much stronger and have more torque on a real charge. LiPo friendly up to 2s just not cut off. Hope it helps man.
