I'm on a ruckus 4wd and the axis is 6 mm thickYes the traxxas ones work. I'm horrible with the internet so no links. The hexes are pretty standard for 12mm, alot of them have a 4mm axle. I even ran axial hexes on mine for a while. They fit the stock rims but not my newer proline rims, so I changed to traxxas slash hexes.
Yes the diameter inside the bearings is 6 mmHmm. I have a couple 2wds. Wouldn't expect that much of a difference in the 4x4. Usually a 6mm axle stub would take a 14 or 17 mm hex. New to me, so I guess I'm not much help then. Are your wheel bearings 6mm in the inside diameter? Seems odd ecx would change them. But I've never seen one so wouldn't know.
Be careful with this measurement, because ECX uses a stepped drive axle. You are correct that the inside diameter of the bearing is 6mm, but the inside diameter of the wheel hexes is 5mm. That's because of the step that I mentioned. So, if you're using stock axles, you'll want a wheel hex that has a 5mm hole.Yes the diameter inside the bearings is 6 mm
I bought these a month earlier. They have an inner diameter of 5mm they can not adapt :https://www.amazon.fr/gp/product/B074NP3JFT/ref=ppx_yo_dt_b_asin_title_o04__o00_s00?ie=UTF8&psc=1Be careful with this measurement, because ECX uses a stepped drive axle. You are correct that the inside diameter of the bearing is 6mm, but the inside diameter of the wheel hexes is 5mm. That's because of the step that I mentioned. So, if you're using stock axles, you'll want a wheel hex that has a 5mm hole.
Here are some 12mm hexes with 5mm holes that will work. They're under $5.00 including shipping to the US, but the shipping may be a little different to France.
