I have to mention that the ECX metal gear set isn’t really the best especially if you are going to run locked slipper I destroyed three $25 gear sets running my car on locked slipper it isn’t too pretty.
Yea your gonna notice that if you get multiple ECX rcs because their tire compounds are way too hard and tend to have terrible grip. They are great if the driver likes to run off-road and soft terrain because they dig in well. But anything else and it’s trash. Pro lines are great tires hope they work out for you.
I’m pretty surprised that the plastic around the pin in the top shaft stripped, never seen that before.
I used to have a torment that had plastic gears in it and I ran it so much that they started melting I just had some cheap black grease on them and it all flung off. 4000kv top speed around 43mph started making weird noises never shreaded the teeth off the gears themselves before I swapped them for metals!
Yea that is really stange.
Did you happen to get the traxxas tranny parts yet?
I destroyed my plastic gears on the stock motor lol. Surprised they lasted even 1 run.
Did some speed runs on the street last night and stripped the plastic gears in my Torment. Was hard to get the top shaft out as it was embedded in the gear. Knew it was going to happen just upgraded to Brushless, so had the metal gears in the spares box. Have now seen the top gear stripped out like you twice. My sons Ruckus and my Torment. Its the torque from brushless and running on high traction surfaces.
On the Traxxas clutch, just watched a video on youtube. Mr Highpower82 has mod 1 traxxas spur and clutch in his. Says he did a mod to the top shaft, not sure what he did, but it has been done
I know that with stock motor & esc with my 5000mAh venom BP (Nimh), I was able to pop wheelies on initial acceleration when I phenagled (pretty sure that's how you spell it) with alternating throttle and brake, however, currently I do not have enough balls out power to do them on command @ speed...though I want to...badly....The ecx amp mt chassic is really light. Add a lipo and heavy brushless motor in the back and you'll carry the front end all day.
Are there any threads out there with help on how to adjust gearing? Cause when it comes to technical adjustments that I am reading about everybody doing I don't even know where to begin.I went cheap on the firs upgrades as i'm saving for a nice castle sidewinder. Amazon has nice brushless kits for around $60-$80. with my 2150Kv and 80 amp ESC it hauls. I did run for awhile the stock setup on a 3S 2200mAh lipo and as it was a huge power increase it took a lot to lift the wheels of the ground. You can also change up your gearing and it would help you wheelie a bit more, if that's your intended goal.
@RookieBasher_92 here is a fantastic document that explains pretty much all you'd need to know about RC car gearing: Associated's "Understanding gear ratios."
Take your time-- there's a lot to learn and you don't need to be able to adjust everything immediately!
