- Location
- Lexington, KY
ECX Ruckus Manual
ECX Ruckus 2WD Parts List
ECX2008 - Main Chassis
ECX1028 - Servo Saver Set
ECX2011 - Cover and Rear Mount
ECX1050 - Setscrew M3x12 (4)
ECX2015 - Foam Block
ECX1098 - Motor Screw/Washer
ECX1058 - Ball Stud (6)
ECX1065 - Shoulder Screw Set (8)
SPMSR201 - 2-Ch DSM Sport
ECX13000 - Waterproof Steering
ECX231003 - Battery Hold Down
ECX231002 - Rear Bumper Set
ECX2006 - Suspension Arm Mount
ECX43008 - Mounted Wheel/Tire
ECX1015 - Wheel Bearing Set
ECX1018 - Front Suspension Arm
ECX1020 - Shock Tower Set
ECX1035 - Front Axle (2)
ECX1044 - Hinge Pin Set
ECX1046 - Camber, Toe Link Set Spur
ECX1049 - Wheel Pins (4)
ECX1060 - M4 Locknut (4)
ECX234000 - Steering Block, Rear
ECX1019 - Rear Suspension Arm
ECX1021 - Transmission Case Set
ECX232001 - Rear Axle (2)
ECX232005 - Driveshaft Pivot Ball (4)
ECX232002 - Driveshafts (2)
ECX1045 - Hinge Pin Screws (8)
DYN4925WP - ESC Regler / ESC
ECX1037 - Shock Caps, Pistons
ECX1027 - Gear Cover Gear Cover
ECX1022 - Transmission Gear Set
ECX1024 - Slipper Clutch Plates
ECX1025 - Transmission Idler
ECX1026 - Transmission Drive
ECX1052 - Washer Set
ECX1055 - Bearings 10x15x4 (2)
ECX1059 - M3 Locknut (4)
ECX232006 - Spur Gear
ECX232007 - 18-Tooth Pinion Gear
DYN1172 - Motor Motor
ECX1048 - Body Clip Body
ECX2010 - Body Post Set
ECX2009 - Body Mount Set
ECX2007 - Skid Plate Set
ECX2013 - Rear Holder Set
ECX1023 - Top Shaft/Spacer
ECX1033 - Setscrew M3x10
ECX231001 - Front Bumper Set
ECX230002 - Painted Body Charcoal / Silver
ECX230003 - Painted Body Green/ Black
SPM2300 - Transmitter
DYN4113 - 2A Peak Charger
DYN1050EC - Ni-MH battery
