AlwaysAmp'd666
Replacement shoulder screws turned up.. 3 different sizes ? i assume its the smaller 4 screws ? then went on to remove the hex nut as to remove the wheel for access and nothing.. any help appreciated. Thanks.
Just wouldn't move at all.. didn't won't to force it in case it was.. will keep at it.Yes it's the smallest ones.
What do you mean nothing? Just hold the wheel, take off the lock nut that holds the wheel to the axle (while holding the wheel itself), then pull the wheel off the axle. It's not held on by anything but the outside lock nut.
