wizardwerx8
- Location
- Springfield MO
Is it necessary to water break in your motor? How beneficial is it to break it in that way?
As you can see @wizardwerx8, your mileage may vary on this stuff. I definitely agree on cleaning the motor regularly—that will nearly always improve performance and lengthen the motor's life. Whichever method you choose, definitely clean the motor regularly.I've performed the water break-in method on two motors. This was in March. Both motors are doing well and one (in my Boost) was subjected to racing conditions early in its life. Slightly higher gearing than box stock and long run times at high output. That and the other motor are both still running well.
I also periodically spray the brushes with motor cleaner spray until it runs clear (initially the black contaminants are very obvious).
Dynamite 20T motors.
