Need help installing RPM servo saver eliminator
Joshnewb
i've got the front skid plate removed, but i can't get the screw out to remove the bell crank
what have i forgotten or done wrong?
please help, frustrated and stuck
There should be a grey cover on the top of the body. 2 screws closest to the battery space remove those screws and pull up and back on the cover it should come off easily.
Next you should see the servo and receiver where the cover was. There will be 2 screws in front of that and take those out. The bell crank will be removable when the higher one is removed. Remove both of you have the whole rpm assembly. There's an attachment with the picture of the cover
