MADitto
I have seen this issued mentioned in a few different post.
I am having the same problem. I have lost at least 3 shoulder screws.
Form what I can see the friction from the caster block on the screw is backing the screw out as you turn the wheels. I have tried a small out of gear grease, that helped it from binding but they still back out. If I tighten it too much it binds.
I was thinking of over boring the holes and putting in a small baring or if I can match the current hole diameter with a metal sleeve so I can use a standard fine thread screw and get deeper into the steering arm.
Does anyone have a better solution?
