SUV body on amp MT?
RC Rebels
Pittsburgh Pennsylvania
Has anyone put a SUV body on your amp MT? If so what did you use to move your body mounts?
I'm installing the apocalypse body from proline. And adding the exo cage from the traxxas summit. But the stock body mounts are to short and not even close to being where they are needed.
If anyone has any direction on this please comment. Or if you have a lead on where to find a universal body mount kit that may possibly work.
So I was able to resolve my front mount issue Actualy very easily. I have the traxxas grave digger body mount posts. I removed the stock amp body posts from the bracket. Drilled the holes out just a tad bigger on the bracket and was able to fit the traxxas post thru stock bracket. This moving it a bit more forward and gaining the hight needed to mount the body. With out having front tire rubbing issues.
Still working on a plan for the rear. I do like the pen casing idea. But would like to have the mounts a bit farther back.
But here is a pic of the front body mounts after some reworking IMG_20170414_083139.webp
The Torment rear post mount would move it back a little, but probably not much more than half an inch.
If you do the torment rear mounts you have to change the shock tower to the torment rear. Bolts right on and the height is adjustable.
