I really need a metal servo for my ECX amp, I bought one on amazon, but it is way too big for the amp, even though it is for 1/10. Can someone leave a link of a metal servo that fits the ECX amp perfectly? Please? Thank you!
Do I have to modify the actual screws or anything? Cause that servo is 1/8..?
Just a strange question, but what makes a servo 1/10 or 1/8? Cause the 1/8 is the same size as the 1/10No use the same holes and stock plastic servo horn. If you use the metal horn that came with your Animos servo then you would have to modify slightly the metal horn.
Also, is there any cheap servo that is waterproof and has metal gears and fits the amp?
Alrighty just wanted to make sure if it was waterproof, it did not say waterproof on the servo or in the descriptionThe servo I told you about the KS-5031-09MW is waterproof and metal geared. This link https://www.ebay.com/itm/Kyosho-1-8...tIAAOSwKIdaUGp-:sc:USPSFirstClass!36109!US!-1 only $12 shipping included right now.
Have you used it under a hose? I will hose down my trucks
