After much throwaway brushed esc wheels shocks hubs spurs... Stock Mobil 1 syn greased f/r metal diffs... 13T+39T 1:3 ratio after breaking 4 sets with diff fluid... since April 2019.
Stock 3rd center alu driveshaft on broken diffs
4S 50C basher...
Hobbywing 4268SL 2600kv 5mm brushless motor 3000W.
AARMA Outcast BLX185 150A esc + 6.5mm to 4mm connection 3-6S. Punch settings 1-9
20kg digital all metal servo.
Hot Racing hardened steel 45T mod 1.0 spur + light white lithium grease = smooth less motor load.
Robinson Racing HS 14T mod 1.0 5mm pinion.
HotRacing (HR) front alu hub carriers
HR alu front steering brace
HR alu servo saver with bearings
Replaced screws with all Axial hex screwset
PROLINE retrofit body supports
PROLINE Brute Basher body
PROLINE 2.8 MX 17mm
badlands on F11
HR alu 17mm 10mm offset adapters
Stock spectrum 3ch rec+trans
50MPH +
4S 50C basher...
PROLINE 2.8 MX 17mm
badlands on F11
50MPH +
