hi, been running this car for while but have problem with stripped plastic spur. when using a heavier arrma motor and tightening the screws it seems to warp plastic motor mount causing spur and pinion not to sit flat, did 4 runs and no problem, then next day out stripped in 1st run! they should still make the metal motor mount for this car, bad plastic motor mount. even my pinion not even mesh all around spur gear???? cause mount is warped!
