ive seen china make metal ones for traxxas cars but not this one? why coudnt hot racing make one?
probably going to try one more new gear box, then sell car if stripped again. what about this ax10 metal gearbox some guys using, can you fit stalk circuit gears onto it?
do you guys get warped gear boxes when screwing heavier brushless system like me?Before you go all hog wild with new bits and pieces.
You could try taking the trans apart and heating the side affected up and gently moving it back in shape.
I dont mean melt it back into shape. But heat it up like in an oven slowly then placing it into a fixture of some sort and allowing it to cool down. Once cooled down place it into something with a bit of moisture in it so the plastic can absorb the moisture to make it more playable so it doesn't snap on you for some reason.
Worth a shot, I think. Or just buy a new trans case to start with.
should I sell my circuit before it goes tis up with horizon? can t be stripping gears all the time.do you guys get warped gear boxes when screwing heavier brushless system like me?
Pretty sure I'm still running the stock gearbox on mine.do you guys get warped gear boxes when screwing heavier brushless system like me?
his horizon hobby getting rid of ecx brand???
yes its not the same has you rotate it, this is bad, I told them to need to make metal gear box they never did, if I strip one more spur its gone.
